Certificates for IPSEC vpn clients in ASA 8.0
Answered Question
Mar 11th, 2008
Hello!
I have configured MS CA and i setup vpn client and ASA 7.0 to make tunnel with certificates.
Same configuration does not work with ASA 8.0 I get error
CRYPTO_PKI: Checking to see if an identical cert is
already in the database...
CRYPTO_PKI: looking for cert in handle=d4bb2888, digest=
b8 e5 74 97 f3 bf 25 1c 2e e5 21 3e d1 93 d6 15 | ..t...%...!>....
CRYPTO_PKI: Cert record not found, returning E_NOT_FOUND
CRYPTO_PKI: Cert not found in database.
CRYPTO_PKI: Looking for suitable trustpoints...
CRYPTO_PKI: Found a suitable authenticated trustpoint CA1.
CRYPTO_PKI(make trustedCerts list)CRYPTO_PKI:check_key_usage: Incorrect KeyUsage
(40)
CRYPTO_PKI: Certificate validation: Failed, status: 1873. Attempting to retrieve
revocation status if necessary
ERROR: Certificate validation failed. Peer certificate key usage is invalid, ser
ial number: 250F3ECE0000000009AF, subject name: cn=xxxxx,ou=xxxx,o=xxxxx,c=
xx
CRYPTO_PKI: Certificate not validated
Why the key usage is invalid? What certificate template must be used in MS CA in order to get a regular key usage?
The CA enrollement is terminal.
THANKS!
Correct Answer by Herbert Baerten about 9 years 4 months ago
The cert needs to have the Digital Signature key usage set.
Not sure what templates are available on MS CA, but it should be something like "Ipsec user" I suppose.
To make ASA 8 behave the same as ASA 7 (i.e. disable th check on the cert's key usage), configure:
crypto ca trustpoint
ignore-ipsec-keyusage
Overall Rating: 0 (4 ratings)
Correct Answer
Herbert Baerten Wed, 03/12/2008 - 15:27
  • Cisco Employee,
fisko Thu, 03/13/2008 - 00:45
THANKS!
It is working whit this options!
I also found that "USER" certificate template in MS CA is correct when ipsec-keyusage is turned on!
THNAKS!
sam mackenzie Thu, 02/09/2012 - 05:59
Fantastic, fixed my issue with an upgrade and MS CA also
Thanks a lot!
Sam
