Callback with a USR modem
Mar 11th, 2008
Ok I have a USR modem plugged into the fax line as well as a 2811 router. Aux line was configured with:
1. rtr-1(config)#line 65
2. rtr-1(config-line)#modem inout
3. rtr-1(config-line)#speed 115200
4. rtr-1(config-line)#transport input all
5. rtr-1(config-line)#flowcontrol hardware
6. rtr-1(config-line)#login
7. rtr-1(config-line)#password cisco
4. Use the reverse telnet method on the modem to configure the appropriate initialization string.
rtr-1#Telnet 172.22.53.145 2065
at&f1s0=1
at&w
Ctrl-Shift-6 x
rtr-1#disconnect 1
Closing connection to 172.22.53.145 [confirm]
Then using procomm to call the modem from my pc. Enter the username and pw. But after that I am lost as to what I need to do to enable callback. Anyone have experience doing this before?
