APP-6: Waiting 10 seconds to connect to peer.
tjcouey
Does anyone know what this error means?
"APP-6: Waiting 10 seconds to connect to peer."
I see hundreds of them in my sys.log. I am running a 11506 that we have recently migrated to from a 11503.
pknoops
Level 3
Level 3
The message you mentioned is an indication that the APP session running on the CSS will
connect to the remote peer running app in 10 seconds. This is just an indication and this message is normal. To avoid seeing this message, you need to reduce the logging of APP messages to 5 or lower. To do this, use the command "logging subsystem app level 5"
Pete..
