MSFC on a Catalyst 6509 has gone missing in configuration
Mar 11th, 2008
Normally from the supervisor, I can find the card as follows:
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
From the supervisor I enter sess 15 and I can acces this module.
Now, I get:
sess 15 [enter]
Module 15 is not installed.
Circumstances as follows cause the module to be inaccessible:
When I tried to test upgrading the catOS and IOS on the switch B,
I found that the bootflash was full and the previous IOS had
to be deleted to make room for the new version. I deleted
the IOS file from the bootflash, but the space was not made
available. I then ran the "squeeze" command. However, this
resulted in an error message about the flash is now in a
inconsistent state. I proceeded to reload the IOS and
eventually reset the supervisor card.
After this sequence of events, mod 15 no longer
appeared.
How do I recover this?
vaisharm Tue, 03/11/2008 - 07:45
  • Cisco Employee,
Have you tried session 16? Can you post the 'show mod' ouput?
~Vaibhav
acameron12 Tue, 03/11/2008 - 08:00
See below:
cat6500B> sess 16
Module 16 is not installed.
cat6500B>
cat6500B> sh mod
3 3 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
5 5 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
6 6 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
7 7 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
8 8 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
Mod Module-Name Serial-Num
1 Supervisor SAL08373QJ1
3 Switch Module SAL052794ZA
5 SAL0710A4CV
6 SAL08496RS8
7 SAL081446ZX
8 SAL0725F6PU
Mod MAC-Address(es) Hw Fw Sw
1 00-12-00-3e-72-76 to 00-12-00-3e-72-77 7.5 5.3(2) 6.1(4)
00-12-00-3e-72-74 to 00-12-00-3e-72-75
00-15-c7-cd-ec-00 to 00-15-c7-cd-ef-ff
3 00-05-5f-29-3c-98 to 00-05-5f-29-3c-c7 3.1 5.4(2) 6.1(4)
5 00-0c-30-a4-77-80 to 00-0c-30-a4-77-af 7.0 5.4(2) 6.1(4)
6 00-12-80-10-85-78 to 00-12-80-10-85-a7 9.1 5.4(2) 6.1(4)
7 00-0f-8f-69-08-10 to 00-0f-8f-69-08-3f 9.0 5.4(2) 6.1(4)
8 00-0d-29-5f-bb-70 to 00-0d-29-5f-bb-9f 7.3 5.4(2) 6.1(4)
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw
1 L3 Switching Engine WS-F6K-PFC SAL08363N4J 2.0
acameron12 Wed, 03/12/2008 - 07:25
Hello and thanks for the reponse.
I am able to get to the rommon prompt at
step 2 from which I can proceed to step 13 and issue the dir bootflash: command
cat6500B> (enable) switch console
Trying Router-15...
Connected to Router-15.
Type ^C^C^C to switch back...dir bootflash:
File size Checksum File name
1577680 bytes (0x1812d0) 0xd7e7bae6 c6msfc2-boot-mz.121-2.E.bin
5276508 bytes (0x50835c) 0xcd90c93 c6msfc2-is-mz.121-2.E.bin
rommon 2 >
Which image should I be booting from to recover?
