X2 on 4500 Supervisor V-10GE
Mar 11th, 2008
We have Supervisor V-10GE and I am looking to purchase the correct kit to connect using the 10Gb interfaces.
The 2 switches I am connecting are next to each other and I think that the following interface is correct.
X2-10GB-CX4
But I am not sure what cable I need to purchase? Could someone please advise?
Overall Rating: 5 (1 ratings)
andrew.burns Tue, 03/11/2008 - 09:55
  • Gold, 750 points or more
You can buy a connecting cable from Cisco, part numbers (starting CAB-INF) at the bottom of the page here:
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd801f92aa_ps5251_Products_Data_Sheet.html
Although this is probably the cheapest option the distance is limited to a max of 15m so if you think you might move them further apart than this then maybe a fibre connection would be a better investment.
HTH - plz rate useful posts (not just mine!)
Andrew.
mikedelafield Wed, 03/12/2008 - 05:47
Thanks for the cable advice.
Just one further question...
Each port provides 10Gb; would it be also possible to Etherchannel this connection if required?
andrew.burns Wed, 03/12/2008 - 06:46
There should be no problem with using both 10GE links in a channel, although there is a probably a minimum IOS version required.
Andrew.
