VPN Passthrough question
Mar 11th, 2008
How do I allow VPN passthrough on my ASA 5505? I believe I need to allow at leaste ports 500 udp and 4500 udp and port 50 TCP??
Can someone please give example of correct access-list needed.
Thank you in advance.
CEJ
srue Tue, 03/11/2008 - 11:19
  • Blue, 1500 points or more
here's a generic config for enabling ipsec passthru...
class-map ike_traffic
match port udp eq 500
policy-map global_policy
class ike_traffic
inspect ipsec-pass-thru
access-list outside_in permit udp any any eq 500
access-group outside_in in interface outside
just to be sure, you have a vpn device behind (internal to) the asa 5505 and you're not terminating vpn's on the 5505?
cejhelp04 Tue, 03/11/2008 - 13:02
Thank you srue for your response. I have tried working with the config you posted, but I have not had success so far.
To your question, I am hoping to use the Cisco software VPN client as the endpoint behind the asa 5505.
I am trying to avoid terminating on the 5505 itself, as I would prefer no auto connect, and also want to limit vpn access only to computers with the software client installed.
Is this a logical pursuit?
CEJ
