what is this?
Mar 11th, 2008
Message
Client '00:19:07:94:b9:70' which was associated with AP '00:1c:58:cd:32:e8', interface '0' is excluded. The reason code is '3(802.1X Authentication failed 3 times.)'.
Help
Client '00:19:07:94:b9:70' which was associated with AP '00:1c:58:cd:32:e8', interface '0' is excluded. The reason code is '3'.
and why does it happen
sabhasin Tue, 03/11/2008 - 09:19
that means that the client exclusion feature is enabled on your WLAN (enabled by default, per WLAN) and the particular user has failed 802.1X authentication 3 times. The exclusion policies are defined under "Security > Wireless Protection Policies > Client Exclusion Policies"
meggerman Wed, 03/12/2008 - 04:00
thankyou sabhasin,
why would they typically fail 802.1x authentication 3 times usually ? just bad passwords ? i seem to get this a loads
thanks
Megz
