Cisco 851 slow web access
Mar 11th, 2008
Just installed an 851 at two locations using SDM express, no real features needed but these locations have quite a few computers on the network and the consumer grade routers they've been using were locking up quite regularly.
Upgrade to the new 851 went flawless, with the first company just using SDM express setup. Now the second company, which uses the same ISP was not so flawless. After setting the unit up the internet was very slow, almost dialup speeds. I'm using 10% cpu and 38% memory - any ideas?
paolo bevilacqua Tue, 03/11/2008 - 10:10
  • Hall of Fame,
    Founding Member
Hi, can you send output of "show dsl internface" please.
tftcomputers Tue, 03/11/2008 - 12:47
Not able to console in at this time, would SDM's 'show interfaces' have the info you need?
paolo bevilacqua Tue, 03/11/2008 - 13:47
  • Hall of Fame,
    Founding Member
Not really. For professional results with cisco gear, use cli only.
tftcomputers Wed, 03/12/2008 - 08:25
Ok, at the router using cli, however - it's a cable interface not DSL... any further thoughts?
paolo bevilacqua Wed, 03/12/2008 - 09:04
  • Hall of Fame,
    Founding Member
You're right, my bad, the 851 is ethernet.
Do you have a lot on "inspect" statements as usually sdm does? If so try removing them.
tftcomputers Wed, 03/12/2008 - 09:19
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
That's all I can see...
paolo bevilacqua Wed, 03/12/2008 - 09:21
  • Hall of Fame,
    Founding Member
Try "no ip inspect ..." for all of them.
paolo bevilacqua Wed, 03/12/2008 - 12:04
  • Hall of Fame,
    Founding Member
Try:
interface fa4
no ip inspect DEFAULT100 out
interface vlan1
no ip tcp mss-adjust 1452
no ip route-cache flow
ip route 0.0.0.0 0.0.0.0 72.215.141.X <-- replace with actual default gateway
no ip route 0.0.0.0 0.0.0.0 fa4
