Call Consult Transfer
Mar 11th, 2008
Hi there,
I'm trying to use the CallConsultTransfer step.. but i'm not sure if i'm using this correctly..
CallConsultTransfer will try to reach the destination number, if avaliable, it'll transfer.. if busy, I could play a message.. or redirect to another part os the script..
is it right ?
Not working...
Andrei.
simonandorfi Wed, 03/12/2008 - 02:13
you are talking about CRS?
If you can use the "busy" depends on your deployment. If these numbers are external the UCX will just do "fire and forget" -> This busy can only used with internal devices or other (IP-IVR - CVP) szenarios.
andrei.goncalves Wed, 03/12/2008 - 03:20
Hi !
yes.. I'm using CRS ...
I'm trying to tranfer to another IPphone.. in this same cluster..
is that what CallConsultTransfer does ? check if the number is avaliable... then transfer.. if busy, I could create a prompt till the number is avaliable.
thanks.
simonandorfi Wed, 03/12/2008 - 09:00
for these stes, just use the call redirect step. If destination is busy you can play a promt to the caller and try again in a few secons (or in a loop)
CallConsultTransfer is used for to outpulse DTMF digits once the destination answers.
