router to router vpn prob
I have a client who has a router at a remote site that uses an Ipsec VPN tunnel to access their HQ. I was contacted because out of the blue, they claims that the remote site users were unable to RDP into the terminal server in their HQ.
Their configuration looks like this:
crypto isakmp policy 10
encr aes
authentication pre-share
group 5
crypto isakmp key XXXXXX address 192.168.x.x
crypto ipsec transform-set AES esp-aes esp-sha-hmac
crypto ipsec fragmentation after-encryption
crypto ipsec df-bit clear
crypto map C2CP2N 10 ipsec-isakmp
set peer 192.168.x.x
set transform-set AES
match address C2C40MB
interface GigabitEthernet3/6
description C2B_40MB_ENC
ip address 192.168.y.y 255.255.255.0
logging event link-status
no cdp enable
crypto map C2CP2N
This sounds like a MTU or a DF-bit problem. I did some ping tests that set the "don't fragment" flag in the packet, I found that the router will not drop packets that are 1378 bytes or smaller.
I did a registry hack to one of the PC's at the remote site and hard-coded the MTU to 1378 bytes, and RDP now works. I of course don't want to do this to all the PC's here. So here's my question: What's the most efficient way to permanently fix this? Should I:
-Enable ICMP so that the Path MTU Discovery mechanism can dynamically set the correct MTU?
Or
-Add the "ip mtu 1378" command to int g3/6? (If I do this, I have to remove the "crypto ipsec fragmentation after-encryption" and "crypto ipsec df-bit clear" commands, correct?)
Anything else anyone recommends?
RER
lamav Tue, 03/11/2008 - 12:21
  • Blue, 1500 points or more
RER:
Dynamic path discovery has one problem that happens to be very prevalent:
A router can generate and send an ICMP message but the ICMP message gets blocked by a router or firewall between this router and the sender.
I would take the ip mtu command route.
Victor
cisco24x7 Tue, 03/11/2008 - 17:49
  • Silver, 250 points or more
since we're dealing with tcp traffic, rdp,
do this and it will work:
int f0/0
ip tcp adjust-mss 1300
Your rdp will work after that.
CCIE Security
Well, before I read the responses that were posted here I made some progress. Just to see what would happen, I set the "crypto ipsec fragmentation before-encryption" command on both ends, and RDP started working. This didn't fix all our problems though.
At the same time that RDP stopped working, AD replication stopped working, and sending files from HQ started ending prematurely. They are still not working. Tomorrow, I'm going to try both suggestions posted here and report back.
mbroberson1 Thu, 03/27/2008 - 14:56
Did you ever find a solution to your issue? If so curious to what the fix was.
Brandon
