Hoping for HELP........
Mar 11th, 2008
CUCM 4.2 Pub and SUB at main location additional Sub deployed at remote location. Also at remote location we have another CM Cluster deployed and connected via NGC intercluster Trunk. We are trying to migrate all the remote gateways and endpoints to our Main CM cluster. When we configure 1st remote location gateway to remote Sub from Main CM cluster in-bound calls to remote site work fine, outbound calls through remote connected gateway will not work (receiving reorder) Have configured gateway as H 323 and MGCP with same results. When we switch remote gateway back to original remote CM Cluster everything works just fine. Checked CSS and works OK with other gateway in route list.
reggiepelletier Tue, 03/11/2008 - 13:16
UPDATE to ISSUE.....RESOLVED.....
We resolved the issue, the remote gateway dial-peer's were set to strip the 9 from the dialed number, and we missed seeing that in the heat of the battle. Sorry for the needless question but maybe this will help someone else with the same issue.
