Remote VPN can't ping each other
Mar 11th, 2008
Hi, I just migrated my remote users off of the VPN Concentrator and onto the VPN. Everything works but I just notice that the remote VPN can't ping each other. Did I do something wrong with my NAT statement:
nat (outside) 10 172.20.141.8 255.255.255.248
nat (outside) 10 172.20.141.16 255.255.255.248
nat (outside) 10 172.20.141.24 255.255.255.248
nat (outside) 10 172.20.141.32 255.255.255.248
nat (outside) 10 172.20.141.40 255.255.255.248
nat (outside) 10 172.20.141.48 255.255.255.248
nat (outside) 10 172.20.141.56 255.255.255.248
nat (outside) 10 172.20.141.64 255.255.255.248
nat (outside) 10 172.20.141.72 255.255.255.248
nat (outside) 10 172.20.142.0 255.255.255.248
nat (outside) 10 172.20.144.0 255.255.255.248
nat (outside) 10 172.20.146.0 255.255.255.248
nat (outside) 10 172.20.146.8 255.255.255.248
do I need to add this statement?
nat (outside) 0 access-list inside_nat0_outbound
brettmilborrow Tue, 03/11/2008 - 17:23
If your remote networks are defined correctly in the access list inside_nat0_outbound, then you will need the following:
nat (inside) 0 access-list inside_nat0_outbound
Note the interface specified in brackets is the interface closest to your internal network and not the remote networks as your example shows.
Also, the other nat statements you had will not work in your requirement.
Good Luck!
siskoboy2007 Tue, 03/11/2008 - 18:43
Thanks I'll give it a try. I don't understand why nat (outside) 0 access-list inside_nat0_ won't work.
siskoboy2007 Tue, 03/11/2008 - 18:47
Brett,
I tried nat (inside) 0 access-list inside_nat0_outbound and it still didn't work.
siskoboy2007 Tue, 03/11/2008 - 20:09
Here's how access-list inside_nat0_outbound looks like:
access list inside_nat0_outbound extended permit ip any 172.20.19.64 255.255.255.192
access list inside_nat0_outbound extended permit ip any 172.25.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 172.20.146.0 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.144.0 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.142.0 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.141.16 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.141.24 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.146.8 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.141.8 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.141.32 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.141.40 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.141.48 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.141.56 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.141.64 255.255.255.248
access-list inside_nat0_outbound extended permit ip any 172.20.141.72 255.255.255.248
I applied this: nat (inside) 0 access-list inside_nat0_outbound
and it still doesn't work. From the syslog i get the following:
07:25 PM isi-950-dc-fw01 Error No translation group found for icmp src outside:172.25.1.19 dst outside:172.20.144.1 (type 8, code 0)
07:24 PM isi-950-dc-fw01 Error No translation group found for icmp src outside:172.25.1.19 dst outside:172.20.144.1 (type 8, code 0)
siskoboy2007 Wed, 03/12/2008 - 07:48
Thanks, here it is. Just remember, we have all of our VPN sites coming to us and we don't allow split tunneling.
nat (outside) 10 172.x.141.8 255.255.255.248
nat (outside) 10 172.x.141.16 255.255.255.248
nat (outside) 10 172.x.141.24 255.255.255.248
nat (outside) 10 172.x.141.32 255.255.255.248
nat (outside) 10 172.x.141.40 255.255.255.248
nat (outside) 10 172.x.141.48 255.255.255.248
nat (outside) 10 172.x.141.56 255.255.255.248
nat (outside) 10 172.x.141.64 255.255.255.248
nat (outside) 10 172.x.141.72 255.255.255.248
nat (outside) 10 172.x.142.0 255.255.255.248
nat (outside) 10 172.x.144.0 255.255.255.248
nat (outside) 10 172.x.146.0 255.255.255.248
nat (outside) 10 172.x.146.8 255.255.255.248
nat (outside) 10 172.x.19.0 255.255.255.0
nat (outside) 10 172.x.1.0 255.255.255.0
brettmilborrow Wed, 03/12/2008 - 08:41
you access-list inside_nat0_outbound does not cover the destination ip you are pinging:
172.20.144.1
try adding a new line to your access-list in order to cover that host.
