CCM 6.1
Mar 11th, 2008
I just wanted to get some feedback from forum users regarding CCM 6.1. Is it stable enough to offer to new customers who don't have IP Telephony yet and still on legacy phone systems.
or
Should still offer CCM 4.1(3) or 5.1 platforms in order to achieve stablity and functionality.
Rob Huffman Tue, 03/11/2008 - 16:29
Hi Abbas,
Yes, CCM 6.1 is stable enough for new deployments. There were many bugs in 6.0 but these have been fixed in the new releases. I wouldn't roll out 4.1(3) as it has been announced as End of Life. The feature sets in 6.1 really add alot of nice functionality over 5.1 so I wouldn't go with 5.1 either :)
Hope this helps!
Rob
kevwailes Wed, 03/12/2008 - 10:41
6.1 is good. I just upgrade from 5.0(4) to 6.0 to 6.1 with no problems. Te whisper feature is great.
Kevin
kalesh.kumar Sat, 03/15/2008 - 03:39
watch out during installation of 6.1. We are at the moment having a bug. We have approached the TAC and are trying to resolve it.
The bug comes up when we try to install a subscriber from a remote site. During installation, we reach a point where it tries to establish connectivity with the publisher. Then it gets stuck....
It is actually a reported bug. ID is CSCsk45350. Unfortunately, the workaround is not working as it is mentioned...
rgnelson Sat, 03/15/2008 - 16:46
We just moved from 4.1.3 to 6.1.1, the only issue we have found is Attendant Console's ability to connect has been buggy. We are still working with TAC on the issue, but basically it takes 2 full minutes to find the server and log in, then never populates the directory with status.
Other than that, its very nice. Administration is faster and the expanded feature set is worth the effort.
rgnelson Wed, 03/19/2008 - 09:40
A little update on AC under 6.1. 2 things were required before it started working as it should.
1) Had to set the CUCM servers in the host file even though name resolution was fully working. This still puzzles me.
2)Had to create the ACDeviceAuthenticationUser and associate the users devices to it. The Features and Services Guide made this seem optional but TAC required it.
After that, we are good to go.
