user & pass required for new NM-CUE ????
Mar 11th, 2008
I'm trying to configure NM-CUE Cisco Unity Express 3.0.1 on a 3845
I have already set the commands
interface Service-Engine1/0
ip unnumbered GigabitEthernet0/1
service-module ip address
service-module ip default-gateway
If I try to access by the command :
CME#service-module service-Engine 1/0 session
Trying, 2066 ... Open
User Access Verification
A user and pass is asked but I have no configured nither the user nor the pass, is a new module
Is there a default pass in order to access to the module?
I tried to reset the pass via command but this message is displayed:
Mar 11 18:44:37.521: %SERVICEMODULE-3-PASSWORDRESET: Service module Service-Engine1/0 password reset not supported
C3845-ADVENTERPRISEK9-M), Version 12.4(15)T3
How can I have access to the module?
Brandon Buffin Wed, 03/12/2008 - 06:03
Check the authentication settings on the terminal line associated with the CUE module. In your case you should have "line 66" in your config. Sounds like there is a username/password required for this line.
Hope this helps. If so, please rate the post.
