Telnet to ASA via L2L Tunneling
Mar 11th, 2008
  • Gold, 750 points or more
Hi all,
Scenario:
LAN A (172.16.20.0/24) --> ASA-A <-L2L Tunnel-> ASA-B <--LAN B (192.168.20.0/24)
Now, From LAN A PC , I want to Telnet to INSIDE interface of LAN B ASA (192.168.20.1).
telnet 172.16.20.0 255.255.255. INSIDE
is enabled on ASA B.
Still unable to telnet eighter way. Same thing from LAN B PC to LAN A.
Any suggestions on how can we work out the telnet.
Thank you in advance
MS
brettmilborrow Wed, 03/12/2008 - 01:38
You will also need the following command:
management-access inside
Good Luck!
mvsheik123 Wed, 03/12/2008 - 07:17
That is already existing on both ASAs.
Any other ideas..??
Thank you
MS
mvsheik123 Thu, 03/13/2008 - 11:49
Hi All,
its bug in ASA IOS. Per cisc 7.2.3 is more stable.
Thank you
MS
brettmilborrow Thu, 03/13/2008 - 12:39
I suspect you logged a TAC case and got a reply. Could you post your code version for ref please?
mvsheik123 Sun, 03/16/2008 - 12:26
Thats correct. The IOS is 7.0 (7), but most 7.0 train is effected. I have ASA with 7.2.3... no isues. So per TAC suggestion also, 7.2.3 looks more stable.
hth
MS
