Diagnostics and analysis on Router and ASA
join_sn09
Dear Expert,
I would like to know which command that we can know diagnostics and analysis on router and ASA 5500 ( i mean Like Health, performance) i want to maintenance every the end of month make sure it work properly.
Best Regards,
Join
Danilo Dy
You should have proper monitoring in place and tracking system weekly.
Example 1: You should monitor critical parts of the devices. i.e. using CRICKET or MRTG
- CPU utilization
- Memory utilization
- Interface utilization
- WAN/Internet bandwidth utilization
- Interface errors
Example 2: You should monitor uptime/downtime of the critical devices, connections and interface. i.e. using WhatsUp
Example 3: You should setup a syslog server and configure the devices to send their logs to this syslog. i.e. using KIWI Syslog. There are both free and commercial software that can be configure to track the logs and send it to you via email or text messaging
Example 4: If you use WhatsUp as in Example 2, you can configure the devices to send SNMP-TRAP to it and use SMTP to send email to you or text message it to you.
Example 5: You can create a tracking form to update every week of the status of critical devices and their parts in the past 7 days.
NOTE: All this can be setup in the same server or workstation (beside the tracking form).
Dandy
Join, Dandy have very well nailed down your request in his step by step monitoring recommendation, I have personally used and recommended some of these utilities and prove to be excellent tools for network performance reporting.
These network utilities Dandy mentioned can be found in bellow links .
MRTG - Freeware
http://oss.oetiker.ch/mrtg/index.en.html
Kiwi network utilities - freeware
http://www.kiwisyslog.com/
CRICKET - Freeware
http://cricket.sourceforge.net/
If money if not an object I highly recommend Solarwinds, some tools are free. If you want to combine all network stools into a single SNMP station I highly recommend SolarWinds Engineer tools
http://www.solarwinds.com/products/
WahtsUP gold
http://www.ipswitch.ca/
PRTG - Free Functional DEMO 4 sensors - not freeware
http://www.paessler.com/prtg/trial
Rgds
Jorge
Jorge Rodriguez
