Meetingplace outdial
NguyenThanhAn
Hi experts,
I'm a newbie in Meeting Place,I'm confusing about outdial of Meetingplace system. I'd like to ask cisco experts here about this following: user call to Meetingplace system and connect to meeting ID, then the user (the user has call out right)trigger call out to other two users.And now, three users can talk to each other through this meeting.
I'm wondering which implement conferencing function of the system. Which one,CallManager or Audio Server?
10 Replies 10
okuehn
actually meetingplace is doing the conferencing work and streams the voice to the participants. since meetingplace is responsible, you can also mute participants, see who is talking and also record meetings.
thank for your reply.
Recently, I heard someone said that when call out to the user,Audio Server like a phone Callmanager'll do the conferencing work rather than Audio Server. I think this is reasonless because Cisco meetingplace documents said this outdial feature clearly. I don't understand why someone said as above.
What do you think,experts?
let help me understand about this.
thanks
Hellow every body
I have configured MP 5.4 every thing is working and if i dial from my IPT i can perform every step including scheduling ,attending etc but when i outdial from my meeting place audio server i recieve the error
Placing Call .....Call was unsuccessful: General Outdial error, check the exlog.
and as i look into the eventlogs i see the following
Mon Mar 24 13:53:21 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Mon Mar 24 13:53:35 2008 mpccagent mpapi.cpp 87 INFO MeetingPlace IP o
utdial. Phone=11508 IRC=11 PSTN=11 Unit=0
Mon Mar 24 13:53:35 2008 mpccagent radh323call.cpp 929 INFO Placing H.323 out
dial.
Mon Mar 24 13:53:35 2008 mpccagent radh323call.cpp 943 INFO ID=0x0002 MP RTP
info. IP=172.28.80.18 Port=16500
Mon Mar 24 13:53:35 2008 mpccagent radh323call.cpp 944 INFO ID=0x0002 MP RTCP
info. IP=172.28.80.18 Port=16501
Mon Mar 24 13:53:35 2008 mpccagent radh323call.cpp 814 WARN H323:Hook out con
n, unable to set DSCP (104), error code -2145371143
Mon Mar 24 13:53:35 2008 mpccagent mpipcall.cpp 306 INFO ID=0x0002 MP Rqst
. Msg=5 CPerr=0 SeqNum=0x2
Mon Mar 24 13:53:35 2008 mpccagent mpipcall.cpp 326 INFO ID=0x0002 MP Resp
Mon Mar 24 13:53:35 2008 mpccagent workerthread.cpp86 INFO ID=0x0002 Call en
ded.
Mon Mar 24 13:53:37 2008 MPDatSvc (0x15C8) Information: 03/24/2008 - 13:53 :
Replication Service Request Completed. Count=10058
Mon Mar 24 13:53:51 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Hi experts,
I'm installing Auido Server 8112 and this is my firt time, I configured Auido Server 8112 as configure gude. And when I connect to Audio Server using MeetingTime,but I don't know using which User ID and Password to log in MeetingPlace.
Let help me! thank experts.
If you configured the components of the meeting place correctly then you can log into meeting time through a Password of the Day which will be provided by Cisco TAC Engineer.
I get the same messages:
(read up in time sequence)
I did one for an in-house extension and another for an outside dial pattern. Both failed with the same "MSG=5" condition.
I have double checked all of the Gateway settings and userid/profile settings.
Mon Nov 10 16:38:55 2008 mpccagent workerthread.cpp86 INFO ID=0x0445 Call ended.
Mon Nov 10 16:38:55 2008 mpccagent mpipcall.cpp 326 INFO ID=0x0445 MP Resp. Msg=5 CPerr=0 SeqNum=0x445
Mon Nov 10 16:38:55 2008 mpccagent mpipcall.cpp 306 INFO ID=0x0445 MP Rqst. Msg=5 CPerr=0 SeqNum=0x445
Mon Nov 10 16:38:55 2008 mpccagent radh323call.cpp 826 INFO ID=0x0445 MP RTCP info. IP=10.1.0.27 Port=16481
Mon Nov 10 16:38:55 2008 mpccagent radh323call.cpp 825 INFO ID=0x0445 MP RTP info. IP=10.1.0.27 Port=16480
Mon Nov 10 16:38:55 2008 mpccagent radh323call.cpp 811 INFO Placing H.323 outdial.
Mon Nov 10 16:38:55 2008 mpccagent mpapi.cpp 87 INFO MeetingPlace IP outdial. Phone=17002 IRC=9 PSTN=9 Unit=0
Mon Nov 10 16:53:08 2008 mpccagent workerthread.cpp86 INFO ID=0x0446 Call ended.
Mon Nov 10 16:53:08 2008 mpccagent mpipcall.cpp 326 INFO ID=0x0446 MP Resp. Msg=5 CPerr=0 SeqNum=0x446
Mon Nov 10 16:53:08 2008 mpccagent mpipcall.cpp 306 INFO ID=0x0446 MP Rqst. Msg=5 CPerr=0 SeqNum=0x446
Mon Nov 10 16:53:08 2008 mpccagent radh323call.cpp 826 INFO ID=0x0446 MP RTCP info. IP=10.1.0.27 Port=16491
Mon Nov 10 16:53:08 2008 mpccagent radh323call.cpp 825 INFO ID=0x0446 MP RTP info. IP=10.1.0.27 Port=16490
Mon Nov 10 16:53:08 2008 mpccagent radh323call.cpp 811 INFO Placing H.323 outdial.
Mon Nov 10 16:53:08 2008 mpccagent mpapi.cpp 87 INFO MeetingPlace IP outdial. Phone=818479802923 IRC=10 PSTN=10 Unit=0
also getting this pattern of error messages:
11/10 16:29:13 WARN 0x300d9 0/8, "vuiactgen.cc", 1719 (0xc23, 0x3, 0x4, 0x97)
Place Call Failed. Erc 3107, App 3, App Data 4, Expected App 151
11/10 16:29:13 INFO 0x0 0/3, "cpiphandler.cc", 975 (0x9, 0x9, 0x2, 0)
11/10 16:29:13 INFO 0x0 0/3, "cpiphandler.cc", 958 (0x9, 0x9, 0x1, 0xc23)
11/10 16:29:13 INFO 0x0 0/3, "cpiphandler.cc", 1654 (0x9, 0x9, 0x1, 0xade00006)
11/10 16:29:13 WARN 0x0 0/3, "cpiphandler.cc", 1800 (0x1, 0, 0, 0)
Where are the messages / codes for these ?
Lookin' for leads to track this down.
TIA,
Noe
I have same problem, but I solved it.
you should check versions software compatibility in your system.
good luck!
annt.
Can you be more specific?
which version of which software?
Here is what I have for software versions:
IPACMP8106:tech$ swcheck
Release 5.4.0 (Built 07/19/06 16:57 MPBUILD-R5_4_0_15)
MODULE NAME STATUS VERSION
SIM UP "07/19/06 16:48 MPBUILD-R5_4_0_15"
LSH UP "07/19/06 16:31 MPBUILD-R5_4_0_15"
SNMPD UP "07/19/06 16:59 MPBUILD-R5_4_0_15"
DBSERVER UP "07/19/06 16:35 MPBUILD-R5_4_0_15"
DBQSERVER UP "07/19/06 16:35 MPBUILD-R5_4_0_15"
POSERVER UP "07/19/06 16:43 MPBUILD-R5_4_0_15"
CPSERVER UP "07/19/06 16:42 MPBUILD-R5_4_0_15"
CONFSCHED UP "07/19/06 16:47 MPBUILD-R5_4_0_15"
WSSERVER UP "07/19/06 16:48 MPBUILD-R5_4_0_15"
VOICESERVER UP "07/19/06 16:55 MPBUILD-R5_4_0_15"
GWSIMMGR UP "07/19/06 17:03 MPBUILD-R5_4_0_15"
Versions
Modules
MeetingPlace Agent 5.4.70.0
MeetingPlace Audio Service 5.4.70.0
MeetingPlace Conferencing Gateway 5.4.70.0
MeetingPlace Conferencing GCC 5.4.70.0
MeetingPlace Conferencing MCS 5.4.70.0
MeetingPlace Conversion Agent 5.4.70.0
MeetingPlace Gateway SIM 5.2.0.60
MeetingPlace Replication Service 5.4.70.0
MeetingPlace Master Service 5.4.70.0
MeetingPlace Extension 5.4.70.0
MeetingPlace Authentication Filter 5.4.70.0
Thanks that's just what I was looking for.
Noe
