CME: IP Communicator - CTL update failed
Mar 12th, 2008
Friends,
I am using CME 4.1 on 2811 router and registering IP communicator
2.1.1.0with it. there are two problems i m facing that i think
interconnect with
each other.
First, when i run ip communicator softphone, phone successfully register
with cme but in status messages it show error messages you can see below:
Error Verifying Config Info
SEP00123F0ACD79.cnf.xml
CTL update failed
Other issue is when i make call from one softphone to other, call connected
successfully but if i press Hold button, i don't hear moh i stored in flash
and configured with moh command. Please go through the configuration find
below:
telephony-service
max-ephones 20
max-dn 20
ip source-address 10.0.0.2 port 2000
cnf-file location flash:
max-conferences 8 gain -6
moh music-on-hold.au
transfer-system full-consult
ephone-dn 1
number 2001
ephone-dn 2
number 2003
ephone 1
device-security-mode none
mac-address 0012.3F0A.CD79
type CIPC
button 1:1
ephone 2
mac-address 000A.E4C3.7199
type CIPC
button 1:2
Please help me regarding these issues.. Waiting for your positive response.
Best Regards
1 vote
Paolo Bevilacqua Wed, 03/12/2008 - 05:30
regarding the ctl files, unless you use phone security, you can ignore that message.
regarding MOH, when you place a call on hold, if the other party is external, will hear MOH, if it is internal will hears periodic beeps.
