guruprasadr Wed, 03/12/2008 - 00:59
  • Gold, 750 points or more
HI Moses, [Pls Rate if HELPS]
I have attached (.zip) the "3COM TFTP SERVER" with the POST.
Download and use for the Backup of your RUnning COnfiguration.
Fyi, 3COM TFTP SERVER is the best recommended for CISCO Products.
Hope I am Informative
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Goutam Sanyal Wed, 03/12/2008 - 02:31
  • Silver, 250 points or more
Hi Moses,
I'd like to suggest you to use the same which was sended by Guru Prasad. Easy to use and reliable.
Goutam
paolo bevilacqua Wed, 03/12/2008 - 02:50
  • Hall of Fame,
    Founding Member
ftpd32.exe is the de facto standard and is recommended by cisco. It aslo supports options that are necessary with ip phone.
beside, a 3com software hosted into an official cisco forum? Shock and horror!
