Unity 5.x GSM Tool - Subscriber Move
Answered Question
Mar 12th, 2008
hi,
i have 4 Unity Server in one Dialing Domain (one domain - different AD Sites)- running well.
One Subscriber moves from Location 1 to 2 and therefore i will change him from Unity Server 1 to Unity Server 2.
I use the Global Subscribe Manager Tool to mover the Subscriber from Unity 1 to Unity 2 - but i have no choice in the Point "Select Destination System" (look at the attached PDF)
I shared the Stream Files directory on all Unity Servers - The GSM User has full access to this directory ;
Any Ideas to solve the problem ?
Thank you
kind regards
alex
Correct Answer by Tommer Catlin about 9 years 3 months ago
You need to make sure you have setup the Dialing domain between the two unity servers. For instanace: Dialing Domain 100
Unity server 1 : 101 (ID)
Unity Server 2: 202 (ID)
These servers also must be in the same domain. If they are not, then you can not digitally network, nor can you use the GSM tool.
hope this helps
Overall Rating: 5 (1 ratings)
Correct Answer
Tommer Catlin Wed, 03/12/2008 - 08:52
  • Green, 3000 points or more
hope this helps
Jason Aarons Mon, 01/26/2009 - 13:50
  • Bronze, 100 points or more
I have the same issue with Unity UM 5.0(1). Two servers are in same Dialing Domain with different Dial IDs. I can use the Directory Handler to find subscribers on the other Unity location, but I still get no choices under GSMs "Select Destination System"
Tommer Catlin Mon, 01/26/2009 - 21:58
you need to configure the directory handler to search both Unity domains, or local, etc.
f.dilalla Fri, 01/15/2010 - 13:09
I have the same issue, have you resolved ?
Franco
