Basic Question - Setting an interface to default values
Answered Question
Mar 12th, 2008
Is there a command to set an interface back to default values? Rather than go through a series of no commands?
thanks
Correct Answer by mheusing about 9 years 4 months ago
Router(config)# default interface Serial0
should do the trick.
Hope this helps! Please use the rating system.
Regards, Martin
Overall Rating: 5 (1 ratings)
Correct Answer
mheusing Wed, 03/12/2008 - 04:15
  • Cisco Employee,
Regards, Martin
gcossins Wed, 03/12/2008 - 04:19
knew it would be simple - just couldn't find it
