Lotus Sametime, nonat and pix.
Mar 12th, 2008
we need to setup a Lotus Sametime server on a site. With the following setup.
LAN ---- PIX 501 ---- RTR --- (INTERNET)
Now the issue is Lotus Sametime server cannot be NATted like the rest of the internal network.
Can I give it an IP of one of the spare external allocated by our ISP, and then run the identity nat exclusion static line on the pix so that IP is not NATted. Will this work, or do I need it on a dmz or will the 501 (6.3) even run it?
Many thanks for your wisdom.
Daniel.
abinjola Wed, 03/12/2008 - 05:24
  • Cisco Employee,
yes it will work
Suppose Lan Server IP-->1.1.1.1
Put default gateway on server as Pix inside Interface
add no nat rule
access-l abc permit ip host 1.1.1.1 any
nat (inside) 0 access-l abc
see if it works..
