RIPv1 problem, bug oder misunderstanding
Mar 12th, 2008
Hi everybody,
I have a very simple problem using RIPv1 which effectively amazed me.
I tried (just for demonstration purpose) a very simple setup using 4 routers connected in line (1721+2610). They all have RIPv1 enabled. There are only classful net. addresses (no subnets).
The routing table is ok, there's connectivity but ALL the metrics of all the routes are set to one(1). So it seems that ripv1 doesn't increment the metric.
I used #debug ip rip to monitor the updates.
How is that possible? Could it be a bug or there is something I didn't understand right?
Please help me understand this issue.
Many Thanks
P.S. c1700-advsecurityk9-mz.124-12.bin and c2600-i-mz.123-22.bin
mheusing Wed, 03/12/2008 - 04:31
could you please provide your IP addressing, better your config regarding RIP and relevant interfaces.
Regards, Martin
wizassonic Wed, 03/12/2008 - 04:59
Thank you for your fast answer.
In the attachment there is a text file with my setup.
For every router I posted: #sh ip int brief, #sh ip protocols, #sh ip route and #debug ip rip for the router that should increment the metric.
Thank you again for you time
tomekf Fri, 04/11/2008 - 02:07
Hello
I also met this problem on routers 2800 1800 7200. and ios 12.4(18) 12.4T(15)
In my labbing I observe that there is something wrong with metric 1 and auto-sumarization.
In RIPv1 when I make redistribution with metric 1 on other routers the redistributed route has metric 1. When I change the metric to 2 or more on the remaining routers the metric is incresed.
When I change the rip to version 2 the metric everywhere is 1. But when I turn off auto-summary the metric (hop count) are set ok.
best regars
tomekf
