CWDM Question
Mar 12th, 2008
  • Gold, 750 points or more
To to pick your brain i have 2 pairs of dark fibers between two datacenters. Dark fibers are terminating on 8 Port channel CWDM and have two pairs of catalyst 6509 switches connecting to the CWDM using 2 channels each at each datacenters. The connection between the 6509's via CWDM are Layer 3 routing usinf EIGRP. I would like to also have a layer 2 connecting between the datacenters since i have few spare channels on the CWDM for server clustering ( two servers between DC need to be on same subnet) and don't want to encounter any STP issues between the 6509 switches. How can i achieve this?
My idea:
Dont have any layer 2 connection on the 6500's since they are core and connect another pairs of Catalyst 4507 at each datacenter to the spare channels on the CWDM and have a layer 2 trunk between the datacenters from the catalyst 4507 acting as a distribution switches passing frames between the two servers via layer 2 for vlan 95 and have the 4507 connect to the Core 6509 via layer 3 routing. So the cat catalyst 4707 will act as a distribution and access.
will my idea work?
Thanks.
Jon Marshall Wed, 03/12/2008 - 11:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
At a high level i cannot see why this wouldn't work although perhaps you may consider eiher 3750-E or 4948 switches rather than the 4500 switch which seems slight overkill for forming a separate L2 link.
You don't say what function your 6500's serve but assuming they are core within your DC's i would support separate switches for L2 connectivty if you can afford it.
Jon
damonli Wed, 03/12/2008 - 12:00
  • Cisco Employee,
For high availability and redundancy, consider two pairs of CAT 6500s with VSS on each DC. Use multi-chassis etherchannel on the CWDM links between the VSS switches. No STP what so ever.
Damon
