ipv6 on 2610xm
Mar 12th, 2008
hi,
is it possible to route ipv6 on this plateform with ios c2600-i-mz-123-17a and how?
flash 16mo
ram 32mo
thanx
mheusing Wed, 03/12/2008 - 06:28
according to the Feature navigator (www.cisco.com/go/fn) the 2610XM supports IPv6, yet not with the feature set of your IOS image.
The minimum requirements for a feature set (IP PLUS or better) supporting IPv6 are 64M RAM and 16M flash f.e. with c2600-is-mz.122-11.T11.bin
With the latest versions (12.4) you will need 128M RAM and 32M flash.
So you would need to upgrade your memory at least.
As to how the configuration should look like, please have a look at the IPv6 configuration guide f.e. at
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-roadmap.html
Regards, Martin
