Radius Support for AAA
Mar 12th, 2008
I have a number of 3500XL and 2950 switches in the Enterprise. I was hoping to get away with MS Radius to control Authentication to the switches. I know these switches supported TACACS+. They do not seem to support Radius. Is there a certain revision of IOS required for these devices to support Radius?
If not, can anyone recommend a TACAS platform other than ACS? I think I read on this forum a shareware version at one time?
Thank you
Overall Rating: 3.7 (3 ratings)
Richard Burts Wed, 03/12/2008 - 11:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Randy
I am not sure what the issue is that you face. I have checked on a couple of 2950 switches and Radius is supported on them. I checked the feature navigator on the Cisco web site and it appears to be supported in both SI and EI versions for the 2950. I do not have a 3500XL but would be surprised if Radius were not supported on it also.
Are you saying that you go into config mode and in global config the command radius-server is not there?
Rick
moorera Thu, 03/13/2008 - 06:36
Thanks for the reply. Sadly Ihave a ton of 3500xl's still. Hoping in the next 24 months to get rid of them. I'll dig in a little more on the 2950s. Thank you.
Lori St. John Thu, 03/13/2008 - 12:00
Rick,
Hi, I actually work for Randy. Here is what I'm seeing, when I'm in global config mode, there is NO command for radius-server.
kka Thu, 03/13/2008 - 12:51
Looks like you didn't enable "aaa new-model".
Here is a working config example with local "fallback":
aaa new-model
aaa authentication login default group radius local-case
aaa authorization exec default group radius local
aaa accounting update periodic 60
aaa accounting exec default start-stop group radius
username admin password ...
radius-server host 172.17.172.17 auth-port 1812 acct-port 1813 key ...
Lori St. John Thu, 03/13/2008 - 13:09
got all that, the only problem is the "radius-server" command is still not available.
kka Thu, 03/13/2008 - 13:21
What exact model and IOS-version are you using?
kka Wed, 03/12/2008 - 23:23
For the 3500XL use at least 12.0(5)WC11, it's important to supply
"Service-Type = Administrative-User" in the Access-Accept (not
necessary on routers with IOS >= 12.3)
The following test entries are for FreeRADIUS and work with
3500XL [12.0(5)WC1x] and 3550 [12.2]:
lvl15 Auth-Type:= Local, User-Password == 'geheim'
Service-Type = Administrative-User,
cisco-avpair = "shell:priv-lvl=15"
lvl1 Auth-Type:= Local, User-Password == 'geheim'
cisco-avpair = "shell:priv-lvl=1"
Richard Burts Thu, 03/13/2008 - 13:58
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
This link posted by Herbert does claim that at least some versions of code (specifically 12.0(5)WC4 and 12.0(5)WC5) do support Radius:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/swg/swsyst.html#wp1097321
The version of code that they are running (12.0(5)WC3b) pretty clearly does not support Radius.
Rick
Lori St. John Thu, 03/13/2008 - 14:08
Thanks to all who responded.
Just to reiterate Rick's post, in case someone else finds themself in the same situation, the version we are running (12.0(5)WC3b) does not support Radius.
