Quick question about 6506 Temperature readings
Mar 12th, 2008
According to this what temperature is the one I should be concerned with regarding the closet temeprature? I need to determine which closet is running the hottest.
6506_WC01#sh env temp
VTT 1 outlet temperature: 37C
VTT 2 outlet temperature: 40C
VTT 3 outlet temperature: 44C
module 1 outlet temperature: 57C
module 1 inlet temperature: 39C
module 2 outlet temperature: 38C
module 2 inlet temperature: 36C
module 2 VDB outlet temperature: 42C
module 2 VDB inlet temperature: 39C
module 2 VDB device-1 temperature: 41C
module 3 outlet temperature: 37C
module 3 inlet temperature: 36C
module 3 device-1 temperature: 36C
module 3 device-2 temperature: 38C
module 3 VDB outlet temperature: 37C
module 3 VDB inlet temperature: 39C
module 3 VDB device-1 temperature: 37C
module 4 outlet temperature: 36C
module 4 inlet temperature: 35C
module 4 VDB outlet temperature: 41C
module 4 VDB inlet temperature: 39C
module 4 VDB device-1 temperature: 39C
module 5 outlet temperature: 37C
module 5 inlet temperature: 33C
module 5 device-1 temperature: 42C
module 5 device-2 temperature: 42C
module 5 asic-1 (SSO-1) temp: 34C
module 5 asic-2 (SSO-2) temp: 35C
module 5 asic-3 (SSO-3) temp: 34C
module 5 asic-4 (SSO-4) temp: 34C
module 5 asic-5 (SSA-1) temp: 34C
module 5 asic-6 (HYPERION-1) temp: 35C
module 5 RP outlet temperature: 37C
module 5 RP inlet temperature: 39C
module 5 EARL outlet temperature: 42C
module 5 EARL inlet temperature: 35C
module 6 outlet temperature: 38C
module 6 inlet temperature: 36C
module 6 device-1 temperature: 37C
module 6 device-2 temperature: 37C
amohabir1 Wed, 03/12/2008 - 08:18
LOL...the easiest thing to do is get a digital thermometer for your closets and have it give you a reading versus trying to figure it out by adding up the temperature from your devices and getting an average.
