CSM 3.1 - Discover Devices
As I knew when we discover devices, it will discover all the devices config and overide the previous copy in CSM DB. Can we SELECTIVELY choose only one device to be discovered ? Otherwise afer discovered we need to re-deploy all again.
Reason is 1 out of 4 firewall managed by CSM. The user access direct to firewall and perform configuration change directly at firewall. Therefore the CSM DB is not in sync with firewall. I just want to discover that unit of firewall.
Jason Gervia Mon, 03/24/2008 - 17:35
  • Cisco Employee,
In device management, if you right click on the device, there should be an option for 'discover policies on device'. You'll have to re-assign any shared policies after discovery, however.
