Route Plan Report
Answered Question
Mar 12th, 2008
Hi, i'm using CM4.2
When I make a Route Plan Report of one extension (example 7032).. It appears 2 times 7032 in the same partition... one is SEP and other is ADP !
SEP0002B341ECAF
ADP0002B341ECAF
What is that ADP for ? Can I remove it ? Why does it appear ?
Thanks.
Andrei.
Correct Answer by Michael Owuor about 9 years 1 month ago
hello Andrei,
ADP = Autogenerated Device profile
The autogenerated device profile, which is a special device profile, gets generated when you configure a phone for Cisco CallManager Extension Mobility and choose "Use Current Device Settings" from the Phone Configuration window. The autogenerated device profile then associates with a specific phone to be the logout device profile.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_1/ccmcfg/b06dvprf.html#wp1028937
Michael.
Overall Rating: 5 (1 ratings)
Correct Answer
Michael Owuor Wed, 03/12/2008 - 09:41
  • Cisco Employee,
hello Andrei,
Michael.
