No translation group found error on site to site VPN.
Answered Question
Mar 12th, 2008
I wondered if anyone could help me. I have basically a site to site VPN (between a ASA 5505 and a Pix 501).
The tunnel is up and seems to be working but they can't access any resources on our side.
I'm getting the following error:
Syslog ID: 305005
Source IP: 172.x.x.x (Internal IP)
Error:
No translation group found for icmp src 10.20.x.x (there IP) dst inside 172.x.x.x (type 8, code 0)
Any ideas on how to fix this?
Thanks.
M.
Correct Answer by acomiskey about 9 years 1 month ago
Your nat exemption should be...
access-list inside_nat0_outbound extended permit ip 172.16.0.0 255.255.0.0 10.2
0.0.0 255.255.0.0
nat (inside) 0 access-list inside_nat0_outbound
Also get rid of...
no nat (outside) 0 access-list outside_nat0_outbound
no access-list outside_nat0_outbound extended permit ip 172.16.0.0 255.255.0.0 10.2
0.0.0 255.255.0.0
Overall Rating: 5 (2 ratings)
brettmilborrow Wed, 03/12/2008 - 13:17
Can you post a copy of your nat, global and static statements and also if any of these reference acl's, then please post those too.
Maccatron Thu, 03/13/2008 - 00:59
Will my sh run do?
: Saved
ASA Version 7.2(2)
hostname ASA
domain-name bah.co.uk
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
ip address 172.16.5.254 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address 82.x.x.x 255.255.255.240
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
passwd xxx
ftp mode passive
dns server-group DefaultDNS
access-list outside_20_cryptomap extended permit ip 172.16.0.0 255.255.0.0 10.20
.0.0 255.255.0.0
0.0.0 255.255.0.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit 172.16.0.0 255.255.0.0 inside
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 172.16.0.0 255.255.0.0
route outside 0.0.0.0 0.0.0.0 82.x.x.x
router rip
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
username Admin password T7lnvpxyyj6WAzfD encrypted privilege 15
http server enable
http 172.16.0.0 255.255.0.0 inside
snmp-server location Mars
snmp-server contact Mr Spoon
snmp-server community Bah
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto map outside_map 20 match address outside_20_cryptomap
crypto map outside_map 20 set pfs
crypto map outside_map 20 set peer 62.x.x.x
crypto map outside_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
tunnel-group 62.x.x.x type ipsec-l2l
tunnel-group 62.x.x.x ipsec-attributes
pre-shared-key *
telnet 172.16.0.0 255.255.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
Any ideas?
M.
Correct Answer
acomiskey Thu, 03/13/2008 - 07:11
  • Green, 3000 points or more
0.0.0 255.255.0.0
Also get rid of...
0.0.0 255.255.0.0
Maccatron Thu, 03/13/2008 - 08:32
Thanks for that. It certainly helped. The only problem I have now is that they can not access any resources.
When I traced the packet it said that it was not allowed due to ipsec spoof.
Any ideas?
M.
Maccatron Fri, 03/14/2008 - 01:34
Actually for some reason something I've changed now allows ICMP to function however I still can't SSH - log below:
ASA# packet-tracer input outside tcp 10.20.15.73 ssh 172.16.4.60 ssh
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 172.16.0.0 255.255.0.0 inside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside_access_in in interface outside
access-list outside_access_in extended permit tcp host 10.20.15.73 host 172.16.4
.60
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT-EXEMPT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
nat (inside) 0 access-list outside_nat0_outbound
match ip inside 172.16.0.0 255.255.0.0 outside any
dynamic translation to pool 1 (82.x.x.x [Interface PAT])
translate_hits = 0, untranslate_hits = 0
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
match ip inside 172.16.0.0 255.255.0.0 inside any
dynamic translation to pool 1 (No matching global)
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: VPN
Subtype: encrypt
Result: DROP
Config:
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Maccatron Sat, 03/15/2008 - 01:32
I also found out that if I changed the tunnel to do not protect then when I did the packet tracing it seemed to work (obviously also adding in an ACL to allow the packet as well).
I'll try this on Monday when I have access to both sites.
M.
M.
