Failover on a router
Answered Question
Mar 12th, 2008
hi all
just wondering is it possible to have failover on router similar to how it is poss on an ASA? at present we have only one router which routes via 3 poss internet connections depending on netwrk add, but what if that router dies?? even i wont be able to get in via SSH to do anything..so to avoid this im looking for a failober router. All help would be appreciated
Correct Answer by massimiliano.se... about 9 years 2 weeks ago
You can implement HSRP (Hot Standby Routing Protocol) which it is similar to active/standby failover mode in ASA world; there is one router "active" and one router in standby..if the active "dies" the standby take the role of active.
Here is a link for configuring HSRP: http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_hsrp.html
HSRP is Cisco proprietary. If you want use a standard with functionality similar, but not equal, to HSRP, you must choose VRRP. Here is a link: http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_vrrp.html
If you want a protocol similar to active/active failover mode in ASA world you have to use GLBP (Gateway Load Balancing Protocol). Here is the link: http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_glbp.html#wp1054488
I hope this helps.
Best regards.
Massimiliano.
Overall Rating: 5 (1 ratings)
Correct Answer
massimiliano.se... Wed, 03/12/2008 - 10:17
  • Silver, 250 points or more
I hope this helps.
Best regards.
Massimiliano.
