P2P VPN with PIX
Answered Question
Mar 12th, 2008
Can someone point me in the right direction for setting this up so I can establish a P2P connection between two sites using the PIX devices at each location?
Correct Answer by Jon Marshall about 9 years 4 months ago
You don't say which version of pix software you are running. Here is a link to a basic site-to-site VPN between 2 pix firewalls for version 6.x. If you are running 7.x there is a link in the document for that as well.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094761.shtml
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 03/12/2008 - 11:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
