Filter Syslog Question
Mar 12th, 2008
I'm hoping someone can point me in the right direction.
I have a router that is running Call Manager Express that is sending a lot of AAA info to a Radius server to support call logging and presence info (UCC). However, all of those AAA messages are also showing up in the log buffer AND on the syslog server.
Problem: I want to see other log messages in the syslog and NOT all the AAA/RADIUS stuff but the AAA and the messages I want to see are of the same severity level. So far I'm at an all or nothing scenario. Is there a way to not send all the AAA/RADIUS junk to the syslog server?
Thanks much.
Joe Clarke Wed, 03/12/2008 - 11:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of IOS is running on this router?
Joe Clarke Wed, 03/12/2008 - 11:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I believe this version supports the Embedded Syslog Manager which will allow you to filter the messages that you do not want. Can you post a whole message that you would like to filter out?
m-ketchum Wed, 03/12/2008 - 11:37
3314819: Mar 12 11:12:40 PDT: %ISDN-6-DISCONNECT: Interface Serial0/0/0:22 disconnected from 5555551234 , call lasted 65 seconds
3314820: Mar 12 11:12:41 PDT: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 94AD2944EF9611DCB414001AA29E1B00, SetupTime 11:11:33.281 PDT Wed Mar 12 2008, PeerAddress 5555551234, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 11:11:35.461 PDT Wed Mar 12 2008, DisconnectTime 11:12:41.071 PDT Wed Mar 12 2008, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 3266, TransmitBytes 548688, ReceivePackets 3271, ReceiveBytes 523360
3314821: Mar 12 11:12:41 PDT: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEATURE_VSA=fn:TWC,ft:03/12/2008 11:11:33.282,cgn:5555551234,cdn:3255,frs:0,fid:999029,fcid:94AD2944EF9611DCB414001AA29E1B00,legID:93E9C
3314822: Mar 12 11:12:53 PDT: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 91378552EF9611DC9C41C6A8127CCABC, SetupTime 11:11:27.477 PDT Wed Mar 12 2008, PeerAddress 3225, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 11:11:41.317 PDT Wed Mar 12 2008, DisconnectTime 11:12:53.747 PDT Wed Mar 12 2008, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 4052, ReceiveBytes 648320
Joe Clarke Wed, 03/12/2008 - 11:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try this. Copy this filter to flash on the router, then configure:
logging filter flash:voip_filter.tcl
logging host x.x.x.x filtered
That should prevent undesired messages from making it to your syslog server.
m-ketchum Thu, 03/13/2008 - 12:12
Thanks for the quick reply and the unexpected file no less!
I won't be able to implement it until this weekend, but will let you know.
Thanks much.
