upgrade IDS 4235 software
Mar 12th, 2008
Hi,i want to upgrade my IDS 4235 from the current version which is Version 4.0(2) to version 6.x, is it possible to step direct to version 6 or i have to go with version 5 first?!
thanks,
Ala
Herbert Baerten Wed, 03/12/2008 - 14:19
  • Cisco Employee,
You need to upgrade to 5.0(1e) first, after that you can go apply service pack 6.0(4) directly.
Herbert Baerten Wed, 03/12/2008 - 23:20
  • Cisco Employee,
True but that would be a re-image (loosing the config), not an upgrade.
