2 questions
devang_etcom Wed, 03/12/2008 - 11:36
  • Gold, 750 points or more
ip rip v2-broadcast will force the router to send the RIPv2 as a broadcast... normally RIPv2 send update using multicast address...
Istvan_Rabai Wed, 03/12/2008 - 13:15
Hi Ali,
In case of the MST, both commands should be OK.
spanning-tree mst 3 root primary
or
spanning-tree mst 3 priority 0
spanning-tree mst 3 root primary will not necessarily set the priority to 0, but to a lower value than the current root priority.
Please be aware, that setting the priority of SW1 to 0 will not make SW1 root if there is another switch in the network with priority 0 and lower mac-address than SW1.
Cheers:
Istvan
