Netconfig deployment
Answered Question
Mar 12th, 2008
Is it possible to deployment multiple CLI Statements to a device. I am planning to deploy the following to all of our Cisco devices on the network via Netconfig.
service tcp-keepalives-in
service tcp-keepalives-out
no ip bootp server
no service pad
no lat enabled
no service tcp-small-servers
no service udp-small-servers
no service finger
Will this run via one job or one job per command?
Correct Answer by Joe Clarke about 8 years 10 months ago
That should be fine. Just make sure you select Config instead of Enable for where to deploy the commands.
This can all be put into one job, and run against multiple devices.
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Wed, 03/12/2008 - 12:39
dionjiles Wed, 03/12/2008 - 12:41
Thanks so much....I was reading chapter 9 in the RME user guide and I was thinking this was going to be a problem. So they way I sent the list of commands is ok right?
Correct Answer
Joe Clarke Wed, 03/12/2008 - 12:57
dionjiles Thu, 03/20/2008 - 10:57
I have one more question regarding this topic....do I supposed to include a write mem in the job for the configs I deploy or does CiscoWorks does this automatically.
Joe Clarke Thu, 03/20/2008 - 11:00
RME does not automatically do a write mem unless you check the "Copy Running Config to Startup" box when scheduling your job.
dionjiles Thu, 03/20/2008 - 11:16
Thanks. That's what I have been doing. Just wanted to verify we have a network audit next week and I want to make sure everything is good.
Joe Clarke Thu, 03/20/2008 - 11:18
You can always check using the RME Out Of Sync Summary under RME > Config Mgmt > Archive Mgmt.
