03-12-2008 12:48 PM
Hi, we currently have HP OpenView Release B.06.31 and will be complementing this NMS with CiscoWorks LMS3.0.1.
Is there an actual CiscoWorks MIB that can be loaded on the OpenView that would provide simple status on the applications within CiscoWorks? I've seen a 3rd party software but am only interested in what OpenView can/can't do.
Steve
03-12-2008 01:19 PM
We don't register any MIB modules with an OS SNMP agent. However, both supported OSes have their own SNMP agents, and they will not conflict with LMS. Therefore, you can run the OS SNMP agent, and monitor the server in NNM as you would any other node on the network. You just won't get any CiscoWorks-specific MIB objects.
03-12-2008 01:23 PM
thanks for the quick response. Makes sense that this is how it would be monitored.
Steve
