Problems with RME Process CTMJrmServer, ICServer & ConfigMgmtServer
I can not see the devices in the RME, the processes are shutdown. I rebooted the server but the process in the window Common Services -> Server -> Admin -> Process say:
CTMJrmServer Administrator has shut down this server
ConfigMgmtServer Administrator has shut down this server
ICServer Administrator has shut down this server
thank for your help
14 Replies 14
Joe Clarke
Please post the entire output of the pdshow command as well as the OS, and version of LMS.
The OS is Windows Server 2003 R2
Estandard Edition
SP1
Cisco Works LMS 2.5
output of pdshow of the server CW is attached
thank for your help
Hopefully it's not LMS 2.5 without patches. If it is, you really need to upgrade. It looks like the root of the problem is that CTMJrmServer is shutdown. Please post the CTMJrmServer.log. Was the hostname changed on this server after LMS was installed?
Thaks for your help
I attached the file CTMJrmServer.log, We dont change the name of the server, it is the same since we installed Cisco Works.
To Upgrade the LMS 2.5, What I have to do.
Please provide the output of netstat -a -n -o -b. To upgrade LMS, you first need to apply the LMS 2.5.1 update. Then you can apply the LMS 2.6 update, then you can download the various service packs on top of 2.6. The downloads can be found at http://www.cisco.com/kobayashi/sw-center/cw2000/lan-planner.shtml . The LMS 2.5.1 update is the LMS 2.5 December 2005 update.
I have to Upgrade LMS or I can wait for your nice commentaries before proceeding with the Upgrade
I attached the output of command netstat -a -n -o -b
I don't see a problem here. Please post the output of pdreg -l CTMJrmServer as well as the NMSROOT\lib\classpath\md.properties and the output of the set command.
good morning Joe
thank to much for your time.
Output pdreg -l CTMJrmServer
C:>pdreg -l CTMJrmServer
Process = CTMJrmServer
Path = D:\PROGRA~1\CSCOpx\bin\cwjava.exe
Flags = -cw D:\PROGRA~1\CSCOpx -cw:jre lib/jre -cp:p MDC/tomcat/w
ebapps/rme/WEB-INF/classes,MDC/tomcat/webapps/rme/WEB-INF/lib/ctm.jar,MDC/tomcat
/webapps/rme/WEB-INF/lib/log4j.jar com.cisco.nm.rmeng.jrmwrapper.server.CTMJobMa
nagerServer 01NI003
Startup = Started automatically at boot.
Dependencies = RMEDbMonitor jrm TomcatMonitor RMECSTMServer
md.properties
NMSROOT=D:/PROGRA~1/CSCOpx
PX_BINDIR=D:/PROGRA~1/CSCOpx/bin
PX_CGIDIR=D:/PROGRA~1/CSCOpx/cgi-bin
PX_LOGDIR=D:/PROGRA~1/CSCOpx/log
PX_TMPDIR=D:/PROGRA~1/CSCOpx/temp
PX_DATADIR=D:/PROGRA~1/CSCOpx/files
PX_DOCDIR=D:/PROGRA~1/CSCOpx/htdocs
PX_CLASSDIR=D:/PROGRA~1/CSCOpx/www/classpath
PX_CGIURL=/cgi-bin
PX_DOCURL=/
PX_CLASSURL=/CSCOnm/classpath
PX_SCLASSDIR=D:/PROGRA~1/CSCOpx/lib/classpath
PX_DATASTORE=DSN=rme
PX_CLASSPATH=D:/PROGRA~1/CSCOpx/lib/classpath;D:/PROGRA~1/CSCOpx/www/classpath;D:/PROGRA~1/CSCOpx/campus/www/classpath;D:/PROGRA~1/CSCOpx/campus/lib/classpath;D:/PROGRA~1/CSCOpx/campus/www/classpath;D:/PROGRA~1/CSCOpx/campus/lib/classpath
PX_APPDIR=D:/PROGRA~1/CSCOpx/objects
PX_CONFDIR=D:/PROGRA~1/CSCOpx/conf
PX_CTRBDIR=D:/PROGRA~1/CSCOpx/contrib
PX_HLPDIR=D:/PROGRA~1/CSCOpx/help
PX_LIBDIR=D:/PROGRA~1/CSCOpx/lib
PX_USER=casuser
PX_GROUP=casusers
PX_STOP_DELAY=3000
PX_SYS_CHECK=1
PX_OSA_PORT=42342
OSAGENT_PORT=42342
PX_HOST=01NI003
PX_FQDN=01NI003
ASANY=D:/PROGRA~1/CSCOpx/objects/db
SQLANY=D:/PROGRA~1/CSCOpx/objects/db
CORE_SECURE_PORT=443
CORE_NONSECURE_PORT=1741
PX_PROTOCOL=https
PX_PORT=443
PX_WEB_PORT=443
MAX_RAM=2048
MAX_SWAP=4096
MAX_CPU=1600
SYS_RAM=0
SYS_CPU=2992
SYS_SWAP=8192
PX_ANI_PORT=42344
thank you
Where is the output of the set command?
sorry,
D:\>set
AdminEmail=claudia.borge@telefonica.com.ni
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\njt00874\Application Data
CLIENTNAME=CM02ITMALW
ClusterLog=C:\WINDOWS\Cluster\cluster.log
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=01NI003
ComSpec=C:\WINDOWS\system32\cmd.exe
CWMIBDIR=D:\PROGRA~1\CSCOpx\objects\share\mibs
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\njt00874
LM_LICENSE_FILE=D:\PROGRA~1\CSCOpx\objects\smarts\conf\trial.dat.DFM
LOGONSERVER=\\01NI003
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=C:\Program Files\Windows Resource Kits\Tools\;D:\Perl\bin;D:\PROGRA~1\CSCOp
x\MDC\tomcat\bin;D:\PROGRA~1\CSCOpx\objects\smarts\lib;D:\PROGRA~1\CSCOpx\object
s\smarts\bin;D:\PROGRA~1\CSCOpx\campus\bin;D:\PROGRA~1\CSCOpx\MDC\Apache;D:\PROG
RA~1\CSCOpx\MDC\jre\bin;D:\PROGRA~1\CSCOpx\MDC\bin;D:\PROGRA~1\CSCOpx\lib\jre\bi
n\server;D:\PROGRA~1\CSCOpx\objects\db\win32;D:\PROGRA~1\CSCOpx\bin;C:\WINDOWS\s
ystem32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 6, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=0f06
PROMPT=$P$G
SESSIONNAME=RDP-Tcp#4
SM_BROKER=01NI003:9002
SM_HOME=D:\PROGRA~1\CSCOpx\objects\smarts
SM_RULESET_PATH=D:\PROGRA~1\CSCOpx\objects\smarts\rules
SM_SITEMOD=D:\PROGRA~1\CSCOpx\objects\smarts\local;D:\PROGRA~1\CSCOpx\objects\sm
arts
SM_SNMP_BUG_COMPATIBLE=1
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\njt00874\LOCALS~1\Temp\2
TMP=C:\DOCUME~1\njt00874\LOCALS~1\Temp\2
USERDOMAIN=01NI003
USERNAME=njt00874
USERPROFILE=C:\Documents and Settings\njt00874
windir=C:\WINDOWS
I don't see anything obviously wrong here. I recommend you go ahead with the upgrade, and if the problem persists, then open a TAC service request. The problem appears to involve the CSTM subsystem, and debugging that is not very straight-forward.
Before doing the upgrade, set your global and per-user TEMP and TMP environment variables to something short like C:\WINDOWS\TEMP, and disable any anti-virus software.
ok Joe
Understood, i will install the updates and I comment on you then.
Thank you for your support
good nigth
I update the LMS to LMS 2.6 and no works, i cant see the devices in the reports
i attach the screen, please help me
thanks
Initially, this looks like there is still a problem with jrm/CTMJrmServer. You will need to open a TAC service request so they can walk you through the debugging steps.
