2960 Ignore VLANs
Mar 12th, 2008
I currently trying to connect a 2960 to a piece of BAXL gear sending out 500 VLANs. My 2960 will only accept 255 VLANs, so I can't send the data through the 2960. The VLANs only need to be kept on the BAXL gear to create Port to Port Security. Is there anyway that I can put two ports on the 2960 into a simple bridge mode where it just forwards traffic(in one port and out the other) and doesn't look at VLANs at all?
Thanks.
