Connection Plar on FXS
Mar 12th, 2008
Hi all,
I have the folowing situation:
I have configure a 2821 mgcp gateway on CM 5.1.2 with EVM-8FXS/DID. On the fxs I only have configure a CSS and the prefix field. Afther i pick up the fxs phone the CM dials the prefix number and the is made sucessufly. If for same reason the called number disconect the call and the calling phone stays off-hook the fxs phone keeps calling the prefix dn every 3 seconds. Is there any way for the callmanager not do dial the prefix dn from the hot line if the hot-line stays off-hook.
auppal Thu, 03/13/2008 - 19:32
  • Cisco Employee,
That is how its designed. Unless the fxs port goes on hook it will keep placing the calls. There is a feature in the VG248 that says
Port busy signaling invoked softkey event
which stops the vg to place a call unless a softkey event end call is received.
patcbr600 Fri, 03/14/2008 - 02:01
That feature is available on mgcp gateways ex:2821
