7921G Phone Book via Webpage
I am setting up phone book's on several 7921G's, and am trying to do so via the webpages. When I try to access the phone book, I get "Access to Phone Book via Webpage is not enabled". I have set the web administration to Full under CCM for the device, but no luck.
I read in the doc for 7921 w/4.3, 5, and 6 that you must also enable phone book access via CCM under the device. Unfortunately, I am on 4.1(3), and the phone book option in CCM does not exist.
For what it is worth, I am also running the latest code, 1.1.1, on the 7921G's.
Overall Rating: 5 (1 ratings)
gogasca Wed, 03/12/2008 - 21:40
I will go for the 4.1(3)ES135 to see if now the "Phone Book Web Access" is enabled...
I see some checks for 7921 FW
Update 7921 CSV and XML files for Release 1.1 FCS
Which should contain that option
You may open a TAC case to get the ES
andrew.campbell... Tue, 05/13/2008 - 20:24
Did anyone find out the service phone command that gives access to the phone book through the Web GUI?
jeff.heckart Wed, 05/14/2008 - 02:32
I actually went to tac and was given an ES for CCM 4.1 that provided this functionality.
andrew.campbell... Wed, 05/14/2008 - 05:48
I've discovered (through trial and error) that if you edit the SEP.cnf.xml file for the phone and add:
You'll be able to access the phone book through the web interface and import/export entries.
