config for enabling SSH
Answered Question
Mar 12th, 2008
The following were added to a Cisco router to enable secure remote access, however the Telnet password is not recognized, thus can not log in to the router. The following is the config. Any suggestions would be appreciated.
ip domain-name yyygroup.com
crypto key gen rsa
1024
ip ssh version 2
ip ssh timeout 60
line vty 0 4
transport input telnet ssh
Correct Answer by Jon Marshall about 9 years 1 month ago
You cannot use the line password for access with ssh. You either need to configure a local username/password on the router for use with ssh or setup ssh access via TACACS+/Radius.
Edit - should have said, to create a local username/password
router(config)# username password
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 03/12/2008 - 15:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
saidfrh Wed, 03/12/2008 - 16:43
Jon,
I entered a user name and password. Puttying in to the remote router asks for a password. The above password associated with the username did not work. After using Putty to access the router, the username was not asked. Any suggestion would be appreciated.
Jon Marshall Wed, 03/12/2008 - 16:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
You need to tell the router that you want to use local authentication ie.
router(config)# aaa authentication login default local
Jon
saidfrh Wed, 03/12/2008 - 20:55
Jon,
Thanks. I selected line authentication option, thus using the Vty passwd to login using SSH/Putty. Do you know how to configure 3Des for encrypting the passwords in the router?
Said
royalblues Thu, 03/13/2008 - 01:06
  • Green, 3000 points or more
Create the username with the secret keyword rather than password which will encrypt the password using MD5
username privelege secret
IF your IOS does not support the secret option, you can use service password-encryption in the global config which will also encrypt the password. This encryption though is very weak and can be cracked using any available password cracking tools
Narayan
