AccessPoint strong signal but little or no connectivity
ougryphon Fri, 03/14/2008 - 13:17
I don't know much about Cisco access points, but my experience with other APs is that when you see a strong signal but no connectivity, your WEP key is wrong. I had this particular problem when mixing D-Link and Dynex equipment because Dynex uses the passphrase to generate a scrambled key whereas the D-Link equipment just took the passphrase and made a key out of the ascii character codes. In any case, the key may or may not be the problem you're having, but I figured I would add my two cents.
scottmac Fri, 03/14/2008 - 16:48
  • Green, 3000 points or more
If by "Little or No Connectivity" you are talking about a Microsoft balloon in the lower right corner of your screen, that is telling you that you are connected, but it didn't get a DHCP address, it's using the APIPA 169.254.x.x.
Verify that you can get to the DHCP server, and that it is responding correctly.
As a quick test, assign an IP address (mask, default gateway, DNS) manually and see if it makes a difference for you.
Good Luck
Scott
