SSH Login
Mar 12th, 2008
Hi, I have make a entry for SSH login or Telnet access on ASA to have rights to do configure tha ASA from outside network but I am not able to login from outside network. As I have done same setting for ASDM http and it is working fine.I am using putty software for this. Can anyone tell me whats a issue??
jkeddington_2 Wed, 03/12/2008 - 22:02
If you have configure SSH access exactly like HTTP and HTTP is working and not SSH then the only thing I can think of you do not have a Crypto key yet. In order for SSH to work you need to configure at least things: Hostname, Domain name and a Crypto key. At the CLI do this: "crypto key generate rsa modulus 1024 noconfirm".
ray_stone Wed, 03/12/2008 - 22:09
How is it possible by using ASDM. Can you please send me the intructions where I have to make changes and is it require crypto setting in telnet case??
jkeddington_2 Wed, 03/12/2008 - 22:17
Here is a link to CCO that will show you have to configure that using the ASDM interface: ""
No you do not need crypto if you are using Telnet. But it is highly recommended that you use SSH if you are going to manage the security appliance using CLI. Otherwise everthing you do will be transmitted in clear text.
