FTP not accessible from IE
Mar 12th, 2008
Hi, I am trying to open FTP from internet explorer but it is not working as If I use same from DOS and its working fine. Can anyone tell me about the issue??
jkeddington_2 Wed, 03/12/2008 - 23:06
You can try checking Internet Options, Advanced and then look for "Use Passive FTP" and select it. Otherwise IE will use Active FTP and usually that does not work when going through a firewall.
ray_stone Wed, 03/12/2008 - 23:14
The setting has been done but still the problem is same..
g-serghiou Thu, 03/13/2008 - 00:25
Check your proxy settings,
also try and use firefox or other software for ftp...sometimes i had "unexplained" problems with IE (timeouts etc)
