cisco CME billing
Mar 13th, 2008
I have to install a CCME in a hotel and my problem is how to do the billing per room and then charge it to the final invoice in the check out.
Is there any billing solution for integrating it in CCME?
Which solution do you recommend?
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Thu, 03/13/2008 - 03:44
  • Hall of Fame,
    Founding Member
One official cisco partner that does this is called stonevoice, there are others as well.
Paolo Bevilacqua Thu, 03/13/2008 - 07:09
  • Hall of Fame,
    Founding Member
Yes in fact an hotel pbx is different in many way from a company one, so for both the configuration and billing you may want to take a specialized approach,
