CCM5.1 Hunt Pilot/Pickup Group
Answered Question
Mar 13th, 2008
Unable to use Pickup for calls from a Hunt Pilot. I've tried the 'CSCsb42763 ' but Pickup Group is still not visible under Hunt Pilot. Does CCM need a reboot after applying the Bug Fix?
Cheers
Rich
Correct Answer by Rob Huffman about 9 years 4 months ago
Hi Rich,
Hope things are going well :) This fix should not require a reboot. I have worked with others here that applied this to CCM 5.1 systems without any issues. Here is the link to the actual TAC Case Collection and a short clip;
In order to enable this functionality in these versions of Cisco CallManager:
Enter CSCsb42763, in mixed case, into the Cisco Support Use 1 Enterprise Parameter under the new Cisco Support use Only group, and click update. Only the CSCsb42763 value in this parameter enables the configuration in step two. Change the value to anything else in order to disable this functionality.
Go to the Hunt Pilot Configuration page, choose a Call Pickup Group from the dropdown list and click update.
For Cisco CallManager 4.2, the same bug is applicable. The only change is that in the enterprise parameter it is called Unsupported Pickup in the CCMAdmin Parameters group.
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K11612191
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 03/13/2008 - 05:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rich,
Hope this helps!
Rob
richb1971 Thu, 03/13/2008 - 05:31
Hi Rob. Thanks for reply. I did a see that earlier post and followed it but Pickup Group is not displayed on Hunt Pilot :(
Rob Huffman Thu, 03/13/2008 - 05:42
  • Hall of Fame,
    Founding Member
Hi Rich,
Well that's no good! What exact 5.1 version are you running? Did you update the enterprise parameters after entering this? Have you tried setting up a new Hunt Pilot since doing this change to see if the Pickup Group option is available on a new Hunt Pilot?
I'm sure we can get this working :)
Let us know,
Rob
David Rickard Wed, 03/19/2008 - 08:40
We've got the same problem! We're on version 5.1.3.1000-12. I've not yet tried the 'fix' (not really 100% sure what to do with it), and I'm seeing quite a bit of conflicting information on what the issue is. Some say it just won't work, some say it does with the fix, and some saying it's intermittent.
I'll be watching with interest!
DWAM_2 Mon, 06/09/2008 - 01:50
do this bug and patch apply to CCM6.0 ?
Best regards.
Rob Huffman Mon, 06/09/2008 - 05:21
  • Hall of Fame,
    Founding Member
Hi Denis,
Yes, this still applies to CCM Versions in the 6.x Train. Have a look at the post from Alexander in this recent thread (Thanks Alexander!);
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Phone%20Services%20for%20End%20Users&topicID=.ee6c82d&fromOutline=true&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbede1c/0
Hope this helps!
Rob
