Warning message
the mean of virtual-address 0.0.0.0 0.0.0.0
Answered Question
Mar 13th, 2008
Hi.Thank for this forum always.
In transparent cache load balancing,
the vip is configured like below,
class-map match-all VIP-TCP80
2 match virtual-address 0.0.0.0 0.0.0.0 tcp eq www
when user want to use a internet, when the traffic reaches msfc, and then the msfc forwarding to ace to lb cache server. right?
just only www traffic.,
Correct Answer by Gilles Dufour about 9 years 5 months ago
yes, that's the way to do it.
Gilles.
Overall Rating: 5 (1 ratings)
Gilles Dufour Thu, 03/13/2008 - 03:27
  • Cisco Employee,
This vip is to catch all http traffic coming into the ace module.
It does not tell the MSFC to forward the http traffic to ACE.
You need policy routing for that.
Gilles.
syjeon Thu, 03/13/2008 - 06:37
Hi. Gilles.
Thank for your help.
you say that the policy routing needed in msfc.
Is there a sample policy routing config on msfc?
syjeon Thu, 03/13/2008 - 06:43
Regarding your comment,I maded a sample configuration.
Can you check for this config?
access-list 101 permit ip any any eq 80
route-map PBR permit 10
match ip address 101
set ip next-hop 192.168.1.2(this is ace client ip address)
inter e0/0
ip policy route-map PBR
end
Correct Answer
Gilles Dufour Thu, 03/13/2008 - 09:15
  • Cisco Employee,
Gilles.
