UCM-BE 6.0- Unity connection issue
Mar 13th, 2008
By mistake i deleted UndeliverableMessages Mailbox Application user(UserManagement>Application User), after that i am not able to get the Voice mail prompt... Can some one suggest to retrive the Application user which i have deleted or any other solution..
Please help me out!!
ebreniz Wed, 03/19/2008 - 09:19
There are a few things to check first:
- does it work with other phones or is it just this phone that does not work?
- does it work on other networks?
- are you using a 790X/791X with hands free? these phones only have monitor, not speaker phone
- if you are dialing with the handset onhook then lifting the handset, make sure your hookswitch is disengaging properly
- if you have ACLs, be sure to have a "log" on any deny statements so you can be sure it's not your ACLs
- check Device license
