brettmilborrow Thu, 03/13/2008 - 15:03
There is no specific configuration to enable this. Provided your tunnel works and is not the hub in an EzVPN solution, the tunnel can be initiated by your ASA.
Are you having an issue with initiating the vpn tunnel?
brettmilborrow Fri, 03/14/2008 - 04:57
The above config will mean that your end will only initiate and will not be the responder.
Is this what you are looking for?
